Hey i was wondering if anyone knew if the Corsair Carbide Series SPEC-03 Black Steel ATX Mid Tower Gaming Case has good cable mangement this will be my setup if its any help
CPU: Intel Core i3-4160 Haswell Dual-Core 3.6GHz LGA 1150 54W Video card: MSI R9 380 GAMING 4G Radeon R9 380 4GB 256-Bit Motherboard: GIGABYTE GA-H97-D3H LGA 1150 Intel H97 HDMI RAM: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 Hard drive: Western Digital Blue WD10EZEX 1TB 7200 RPM SSD: Crucial BX100 CT250BX100SSD1 2.5" 250GB SATA 6Gbps Case: Corsair Carbide Series SPEC-03 Black Steel ATX Mid Tower Gaming Case Power Supply: Cooler Master Elite V2 - 550W
https://linustechtips.com/topic/431416-cable-management/
The cable management is OK. It's average. If you spend some time on the cable managment you'll be able to achieve a clean looking build, but it's not as luxurious with straps everywhere and a huge amount of space as you'd see it in a more expensive case.
This message transmitted on 100% recycled electrons.
https://linustechtips.com/topic/431416-cable-management/#findComment-5784297
