Cant enable nvidia surround. display connection error.
I have attempted to enable nvidia surround However I keep getting display connection error when I select all 3 displays.
All 3 monitors are identical and were purchased at the same time (iiyama GB2488HSU's) and are all identical when opened up in CRU (custom resolution utility) and have the same resolution and refresh rate. (1920x1080@144Hz)
At the moment I have 2 980Ti's in SLI and all monitors are connected to the top card with 3 DP cables. (I have also tried a single card and still no luck)
Any help  will be much appreciated.
