i5 4590 does not boost
Go to solution Solved by incarnate,
I can run BF4, what do you suggest? turbo boost works fine from 3.3 to 3.5 but doesn't reach 3.7 as advertised
It only boosts to 3.7 on one core. If two cores are under heavy load then it boosts to 3.6 and if 3 or 4 are loaded then it boosts to 3.5.
So long story short your cpu is working like it should. Run cinebench single threaded and you should see 3.7
Try running a stress test.
CPU: Intel i5 4690k @ 4.3 GHz       GPU: MSI GTX 980                      Cooling: be quiet! Pure Rock                     OS: Windows 7            Monitor: BenQ XL2411Z
Motherboard: AsRock Z97 PRO4   PSU: Corsair 600W CX600M       Keyboard: Razer BlackWidow Ultimate   SSD: Intel 120GB 520   Headset: HyperX Cloud II
RAM: 12GB Crucial Ballistix            Case: Corsair 750D                       Mouse: Logitech G502                         HDD: Seagate 1TB        Speakers: Audioengine A5+
https://linustechtips.com/topic/430573-i5-4590-does-not-boost/#findComment-5773680
I'm trying right now but it cap's at 3.5
Try a real world stress test. Some synthetic ones don't trigger Turbo Boost.
https://linustechtips.com/topic/430573-i5-4590-does-not-boost/#findComment-5773693
Run BF4 then...
What program are you using to measure clock speed?
https://linustechtips.com/topic/430573-i5-4590-does-not-boost/#findComment-5773714
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/430573-i5-4590-does-not-boost/#findComment-5774001
Thank you
https://linustechtips.com/topic/430573-i5-4590-does-not-boost/#findComment-5774125
Thank you
no problem :)
My rig:
https://linustechtips.com/topic/430573-i5-4590-does-not-boost/#findComment-5777746
