Any website I can send my side panel and have them put in a custom window and maybe leds or stuff?
I'm affraid you'll need to leave house for this one.
Primary: Lenovo T61 / Intel Core2Duo T7200 @ 2.2GHz / 3GB DDR2 / NVIDIA Quadro NVS 140M / Fedora 22 <<<< THE WHITE KNIGHT
Secondary: Compaq Presario CQ56 / AMD V130 @ 2.3GHz / 2GB DDR3 / AMD Radeon HD 4250 / Windows 8.1 <<< THE FORGOTTEN HERO
That would be fairly costly to send back and forth unless they sell you a modified case they purchase. I would say if there is any fabrication shop locally you can mask the entire panel and mark out the cuts for them to cut and install the window material.
LED's are fairly straight forward with pre-made strips you stick and plug in place.
EDIT:
Try contact MNPC tech they might be able to help you out.
Edited by W-L
Performance PC's has a custom case mods service and vinyl cutting service
http://www.performance-pcs.com/special-services/
Insert   Dank   Signature   Here.
