Accelero Xtreme IV 280(x) Problem
Go to solution Solved by Titali,
I contacted with Artic Cooling support and they answered me the following instructions PICTURE: https://gyazo.com/094640c290231802433dccd36fd5df99
I think i can do it!
Bye!!
Hi everybody,
I have a R9 280x rev 2.0 and like 2 weeks ago a fan started to vibrate and spining very very slow, so i decided to buy a new and better cooler, in this case the Accelero Xtreme IV 280(X), I investigated a lot and I was sure it would work. So today I decided to change the stock cooler for the Accelero. When removing the stock cooler the fan power adaptor was stuck in the plug, I finally pulled it out and the cable broke, well I didn't care because I had the new one, but when I checked closely to te fan adaptor of the Accelero i realised that it was a 4 pin adaptor. At the moment i don't have a GPU with cooler I don t know what to do, should i return the cooler and buy another one? Or buy a new GPU?Or buy an adaptor cable that I did not found anywhere!?¿?¿?¿ I prefer to stay with this GPU because I don't have much money for a brand new, but if there is no option I ll probably go for the Msi GTX 960 4GB
I hope someone can help me!!  :)
Pd: sorry for my english level, i m from spain : :P
post-252262-0-89535500-1439493978_thumb.
post-252262-0-72339300-1439494510_thumb.
post-252262-0-49230000-1439494545_thumb.
https://linustechtips.com/topic/429370-accelero-xtreme-iv-280x-problem/
a 4 to 3 pin fan converter might solve your problems if you cant plug it in
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
