Basic builds for all needs! But be aware there is better and/or cheaper parts around but this is what I found so I hope this makes it easier for people to know where to start! (AM3+ socket should not use a cheap motherboard cause it may lead to a fire or thermal throttling...)
PC Build Guide – Console Killer: (Less than 500$)
*CPU: AMD FX-8350 + Wraith Cooler (does not need after market cooler)
*GPU: XFX Radeon R7 360 2GB DD
*Mobo: MSI 970 Gaming ATX AM3+ Motherboard
*RAM: Mushkin Silverline 8GB (2x4GB) DDR3-1333MHz
*PSU: EVGA 500W Power Supply Unit (bronze)
*Storage: Hitachi Ultrastar 500GB 3.5" 7200RPM HDD
*http://pcpartpicker.com/list/FNrXbj
PC Build Guide – AMD A10-APU M-ATX: (Less than 500$)
*CPU: AMD A10-7890K + Wraith Cooler (does not need after market cooler)
*GPU: N/A
*Mobo: MSI A78M-E35 V2 M-ATX FM2+ Motherboard
*RAM: G.Skill Trident X Series 16GB (2x8GB) DDR3-2133MHz
*PSU: XFX TS 550W Power Supply Unit
*Storage: Seagate 2TB 3.5" 7200RPM SSHD
*http://pcpartpicker.com/list/y3MCzM
PC Build Guide – AMD Athlon X4 M-ATX: (Less than 600$)
*CPU: AMD Athlon X4 880K + 125w Near-Silent Thermal Solution (does not need after market cooler)
*GPU:: Gigabyte Radeon RX 480 8GB (can be replaced by RX 470, GTX 970 or R9 390)
*RAM: Corsair Vengeance 16GB (2x8GB) DDR3-1866MHz
*Storage: Seagate 1TB 3.5" 7200RPM SSHD
*http://pcpartpicker.com/list/kvC8JV
PC Build Guide – AMD FX-6300 ATX: (Less than 700$)
*CPU: AMD FX-6300 + Cooler Master Hyper 212 Evo
*GPU: Gigabyte Radeon RX 480 8GB (can be replaced by RX 470, GTX 970 or R9 390)
*PSU: XFX TS 650W Power Supply Unit
*http://pcpartpicker.com/list/KbpgtJ
PC Build Guide – Intel i3 ATX: (Less than 700$)
*CPU: Intel Core i3-6100 (does not need after market cooler)
*Mobo: ASUS H170-PLUS D3 ATX LGA1151 Motherboard
*RAM: Hyper X Fury 16GB (2x8GB) DDR3L-1866MHz (most be 1.35v or less)
*http://pcpartpicker.com/list/3vhDxY
PC Build Guide – AMD FX-8370 ATX: (Less than 800$)
*CPU: AMD FX-8370 + Wraith Cooler (does not need after market cooler)
*GPU: Gigabyte Radeon RX 480 8GB (can be replaced by R9 390, GTX 1060 or R9 Fury)
*http://pcpartpicker.com/list/vMDCLD
PC Build Guide – Intel i5 ATX: (Less than 900$)
*CPU: Intel Core i5-6600K + Cooler Master Hyper 212 Evo
*GPU: Gigabyte Radeon RX 480 8GB (can be replaced by GTX 1060, R9 Fury or GTX 1070)
*Mobo: ASUS Z170-PLUS D3 ATX LGA1151 Motherboard
*http://pcpartpicker.com/list/9zsb8K
PC Build Guide – Intel i7 ATX: (Less than 1000$)
*CPU: Intel Core i7-6700K + Cooler Master Hyper 212 Evo
*http://pcpartpicker.com/list/HzZxcc
Complete Example Build: (your build should look like this when done the green is required)
*Case: Cooler Master HAF XB EVO ATX
*CPU: AMD Phenom II X6 1100T + Cooler Master Hyper 212 Evo
*GPU: Sapphire Radeon R9 290 4GB Vapor-X
*RAM: G.Skill Ares Series 16GB (4x4GB) DDR3-1866MHz
*Operating System: SteamOS or Windows 10
*PSU: EVGA SuperNOVA G2 550W Power Supply Unit
Edit 25-Okt-2015:
Why RAM matters!
My tests: (Both MHz & Latency matters!!!)
Storage Solutions For Operating System:
*Seagate 1TB 3.5" 7200RPM SSHD (75$)
*Samsung 850 EVO-Series 500GB SSD (150$)
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
https://linustechtips.com/topic/427926-basic-builds-for-those-who-need-help/
PC Build Guide – Budget ATX: (600$-800$)
*AMD FX-6300 Black Edition / AMD FX-6350 Black Edition
*Cooler Master Hyper 212 Evo / Cooler Master Seidon 120V
*MSI 970 Gaming, Socket-AM3+ / MSI 990FXA Gaming, Socket-AM3+
*HyperX Savage 1866MHz CL9 4GB (x2)
*Samsung 850 Evo 250GB SSD 2.5” / Samsung 850 Evo 500GB SSD 2.5”
*MSI Radeon R9 380 2GB / MSI Radeon R9 380 4GB
*Cooler Master V650S, 650W PSU
an i5-4460 would be better here
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
lol it wont fit the socket unless you hammer it in...
  • 3 weeks later...
The only relevant cooler for me for AM1 is this one:
http://www.scythe-eu.com/en/products/cpu-cooler/kodati-rev-b.html
Also a nice one is the arctic cooling M1 Passive, which makes total sense for this platform, yet as it's a bit tall it won't fit in small mITX cases (like the M350 or S110)
This is a signature.
That one is very adorable but is it easy to find for all? (world wide)
Which one? The first anywhere where scythe sells their products, at least it's easy to find here (Spain). Make sure is the Rev.B because the first one doesn't include the accesories for AM1.
The second one has decent stock, though I've to buy it from an importer (as always still cheaper than AC's site :/)
  • 4 months later...
A titan X with those cpus? Are you trying to bottle neck the crap out of the gpu?
It is to show how RAM speed affects the CPU bottleneck so yes that is the idea... :)
