Hey guys I was wondering were I could buy some cables that come per sleeved, I am thinking about upgrading the PC to these spec's, could you guys tell me were to buy per-sleeved cables and many I will be needing? I also would like to water cool both Titan's and the CPU if you could tell me what I would be needing for that and were I could buy it, that would be pretty cool to. Any help would be awesome, thanks!
AMD FX-9590 4.7GHz 8-Core OEM/Tray Processor
Corsair H60 54.0 CFM Liquid CPU Cooler
Asus Crosshair V Formula-Z ATX AM3+ Motherboard
Corsair Vengeance LP 32GB (4 x 8GB) DDR3-1866 Memory
Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive
Asus GeForce GTX Titan X 12GB Video Card
Asus Xonar DSX 24-bit 192 KHz Sound Card
\Asus PCE-AC68 802.11a/b/g/n/ac PCI-Express x1 Wi-Fi Adapter
Corsair 900D ATX Super Case
Corsair SP120 57.2 CFM 120mm Fans twin pack
Corsair Air Series AF140 Quiet Edition 67.8 CFM 140mm Fan
Corsair Air Series SP120 Quiet Edition (2-Pack) 37.9 CFM 120mm Fans
Corsair 1200W 80+ Platinum Certified Fully-Modular ATX Power Supply
https://linustechtips.com/topic/426954-need-some-help/
Wtf why do you need all those case fans it's like you want to have a jet engine for a PC also don't get that CPU it isn't good and it's a melt machine get a Intel Skylake or X99 one instead and don't get dual Titan Xs it's a waste of money just get dual 980Tis which is same performance for half the price also do you plan to do a Full custom watercooling loop for the CPU and GPUs otherwise that case is a waste as well.
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/426954-need-some-help/#findComment-5727661
don't get that amd cpu
if you need the cores, get a 5820k and a x99 motherboard
and instead of that titan, save some money and get a 980ti
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
https://linustechtips.com/topic/426954-need-some-help/#findComment-5727715
You were told a few weeks ago multiple things:
No AMD processor can support a single Titan X, much less 2. We understand you want to "stick with AMD to avoid having to switch motherboards" but if you want any semblance of a balanced system that isn't a coplete waste of money, you have to jump ship and go with Intel. And for the budget you're displaying for graphics cards alone, you have absolutely no excuses regarding prices unless Intel is 10 times more expensive where you are (which is unlikely).
Pre-sleeved cables/extensions: Bitfenix has a few options and there are other ranging in price and variation from tri-color to single color, paracord, plastic sleeving, etc. Just look around on amazon and the like.
Cinders: - i7 4790K (4.5GHz) - Gigabyte Z97X-SOC - 16GB Klevv DDR3 1600MHz - EVGA GTX 980Ti ACX2.0+ (1548MHz Boost) - EVGA Supernova 850GS - NZXT H440 Orange/Black (Modified) -
Unnamed System: i5 4690K (4.2GHz) - MSI Z97I-AC - 8GB G.Skill DDR3 2400MHz - EVGA GTX 950 SSC - Raidmax Thunder V2 535W - Phanteks Enthoo Evolv ITX
https://linustechtips.com/topic/426954-need-some-help/#findComment-5733605
