when i was overclocking on my msi mobo i came across cpu ring ratio and i looked it up and it said its the thing that connects all the cores so i put it to 3.4ghz but i dont know how to use it lol so any help is appreciated, my cpu is an i7 5820k @ 4.4ghz
i7 5820K @ 4.4GHz | Evga GTX 980ti Superclocked | MSI X99 Sli Plus | 16GB Crucial Ballistix DDR4 | EVGA 850W Gold+ | 2TB HDD and 250GB SSD
NZXT Phantom 530 | Corsair H100i GTX |
https://linustechtips.com/topic/426863-what-is-ring-ratio/
It's your cache frequency for your CPU.
https://linustechtips.com/topic/426863-what-is-ring-ratio/#findComment-5726400
Its cache, does nothing other than throw out more heat IMO.
Main Rig:-
Server:-
https://linustechtips.com/topic/426863-what-is-ring-ratio/#findComment-5726475
It really doesn't do anything. try increasing it, and my CPU crashes every time xD unless your getting into sub-zero cooling....Don't change it.
The more you know :)
CPU: Pentium G3258 @ 3.2GHz || GPU:(first release,used) MSI R9 270 OC || Motherboard:MSI Z97-G45 Gaming Motherboard || RAM: 8 GB G.Skill Sniper 1600 || Monitors: Vizio 22 in Ultra slim 1080p TV || Storage: Seagate barracuda 160 GB 7200RPM,(REFURB) 1TB toshiba 7200RPM || PSU: (stripped from 2013 CAD PC)Corsair CX600 build was under $420
BE SURE TO FOLLOW YOUR THREADS! READ THIS BEFORE POSTING IN TROUBLESHOOTING!! http://linustechtips.com/main/topic/40334-read-before-asking-for-help/
https://linustechtips.com/topic/426863-what-is-ring-ratio/#findComment-5726579
Are you upping vccin & ring volts?
It helps with benchmarking, and stuff like rendering.  Anything that uses lots of RAM & cache it will help with.  Gaming and things like that it doesn't do much though.
https://linustechtips.com/topic/426863-what-is-ring-ratio/#findComment-5726627
Yeah, I do all the stability jive....but nothing. I only deal with  the CPU ring...Ring ratio just kept it at stock, and upp'd the CPU ring. works fine like that.
https://linustechtips.com/topic/426863-what-is-ring-ratio/#findComment-5726647
