Gpu/motherboard problem
Go to solution Solved by JebKerman,
all of the red slots on that board a 16x PCIe3, even if for what ever reason they aren't, I'm pretty sure GPU's cannot even saurate an 8x PCIe2 slot, and you certainly wont see a performance difference.
well as a quick and simple fix, you could put it in the next 16X slot
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
https://linustechtips.com/topic/426470-gpumotherboard-problem/#findComment-5721975
https://linustechtips.com/topic/426470-gpumotherboard-problem/#findComment-5722146
The chipset cover is not interfering with it but I have already put in the next red slot just to make sure it posted so I guess I will just keep it that way. Thanks for your help guys I just wanted to be sure that my system would be doing the best it could be, this is a pic of it with the gpu installed
https://linustechtips.com/topic/426470-gpumotherboard-problem/#findComment-5722182
