Is this a problem? I'm just watching a youtube video, and the MHz is pretty high. Maybe it is because I'm running two 144hz monitors? Will it eventually damage my video card if I let it run like this all the time?
My current system is: | CPU: i7 2600 3.40GHz | RAM: 12GB Dual Channel DDR3 1600MHZ | Motherboard: CG8350 | Storage: 931GB Seagate+Samsung 850 EVO Series 250GB | GPU: GTX 970 Gaming | PSU: G2 750 | Monitors: 2x BenQ XL2411Z
https://linustechtips.com/topic/425810-is-this-a-problem/
Nothing worrying about 36 degrees.
https://linustechtips.com/topic/425810-is-this-a-problem/#findComment-5714252
0.0..........
Cards idle at higher temps on multi monitor setups... idle temps mean nothing unless its way over the top like 80c+.
https://linustechtips.com/topic/425810-is-this-a-problem/#findComment-5714256
How about the power usage? Considering I'm just watching a video
https://linustechtips.com/topic/425810-is-this-a-problem/#findComment-5714260
Still fine
Curious though; is "Power management mode" in "Global Settings" in NCP set to "Adaptive?
https://linustechtips.com/topic/425810-is-this-a-problem/#findComment-5714289
Still fine
Uhhm, how do I check that?  :D
https://linustechtips.com/topic/425810-is-this-a-problem/#findComment-5714321
Still fine
Yea it was set to adaptive
https://linustechtips.com/topic/425810-is-this-a-problem/#findComment-5714328
Yea, it is set to adaptiv, should it be different?
https://linustechtips.com/topic/425810-is-this-a-problem/#findComment-5714353
Not in global, but I let to set maximum performance in each games' settings.
https://linustechtips.com/topic/425810-is-this-a-problem/#findComment-5714460
