http://www.webhallen.com/se-sv/datorkomponenter/163383-corsair_carbide_200r-svart?atcl=product:suggestions
OR
http://www.webhallen.com/se-sv/datorkomponenter/179732-cooler_master_force_500-svart&atcl=search:live
It will be housing my second PC which I want to have MAXIMUM AIRFLOW. Here are the specs.
CPU- i5 3350p
RAM- 8GB
GPU- GTX670
PSU- TX650
PS: Would prefer to buy the cheap case...
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/424747-need-help-choosing-between-2-cases/
200r. All the d=fan spot on the top and side and I like the look better.
 Just because you don't care, doesn't mean other others don't. Don't be a self-centered asshole. -Thank You a PSA from the people who do not say random shit on the internet.
max airflow would be a test bench
I want maximum airflow out of those cases I mean. If you have a better cheaper suggestion of a case I would be glad to hear it but this PC needs to be in an enclosed case since it will be my LAN rig.
OR
CPU- i5 3350p
RAM- 8GB
GPU- GTX670
PSU- TX650
go with the corsair because you have an option of 2 side fans and even if you choose to use a aftermarket cooler and you cant use your top side fan, heat can still escape through the holes, and heat rises so you can add 2 top exhaust fans
Both of them aren't exactly airflow optimised, but I'd personally take the Corsair 200R.
What case would you recommend for airflow that is around the same price then? Also if the coolermaster force 500 will be just as good for airflow i would like to choose that because it is cheaper.
OR
CPU- i5 3350p
RAM- 8GB
GPU- GTX670
PSU- TX650
how about those aerocool ones in the website choose one that comes with 2-3 fans
This case has MAXIMUM AIRFLOW:
What case are you talking about?
/s
Can you give me a straight reply?
What about this case? http://www.webhallen.com/se-sv/datorkomponenter/183150-aerocool_gt_advance-svart?atcl=product:suggestions
Its cheaper and doesn't seem bad.
What about this one http://www.webhallen.com/se-sv/datorkomponenter/179734-cooler_master_n300-svart?nosto=nosto_mini_recommendations_2#overview
You're probably best off with the N300 unless you want to go for something like the Cooler Master HAF series.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
