Pretty sure the build for my friend is fine, but it is always a good idea to get another pair of eyes. http://pcpartpicker.com/p/scwwbv
BEFORE YOU SAY ANYTHING
- He doesn't want an SSD
- He doesn't want SLI in the future
- HE REALLY WANTS AMAZON
- 750W is overkill, but EVGA is high quality and the second cheapest PSU on amazon was $65 so it was worth $5 extra
- He only ever wants 16GB, so two dimm slots are fine
- I know the 1231v3 doesn't cost anymore, but it is barely an upgrade and I don't want compatibility issues
- Gemini over the Hyper 212 Evo because I want to make sure there is no clearance issues
- I usually prefer the 390X, but it's a small case and I don't want heat issues
- He doesn't care about looks, raw performance
Thanks!
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
https://linustechtips.com/topic/424343-1000-build-help/
get a R9 380 ITX from sapphire, or a R9 380 full size. Those cards are generally pretty cool.
That or get the R9 390X, downclock it a few % to save power and heat
https://linustechtips.com/topic/424343-1000-build-help/#findComment-5696747
Click HERE to see your Build
6600K doesn't have hyperthreading, and he doesn't need 16GB of ram
https://linustechtips.com/topic/424343-1000-build-help/#findComment-5707383
HAHA thats Correct but theres only 2-4 fps difference between the I5 stuff
Not with a 980Ti....
https://linustechtips.com/topic/424343-1000-build-help/#findComment-5708124
