USB 3.0 Hub under $30
Go to solution Solved by Arty,
what do you think of this one?
http://www.amazon.com/AmazonBasics-Port-USB-power-adapter/dp/B00E6GX4BG/ref=sr_1_7?s=pc&ie=UTF8&qid=1438812724&sr=1-7&keywords=usb+3.0+hub
does it have enough power for me to charge 4 phones and one drive, and an ipad?
Why are you chraging all of that at one time any way lol
and remember that phones need a min of .5 amps and ipad needs 2amp
ithink the other one is faster overall.
this one wont work well with your ipad
"Note: This product is not intended to charge iPads/other tablets"
I was looking at this: http://www.amazon.com/Sabrent-Charging-Ports-Adapter-HB-U930/dp/B00SIQIV04/ref=sr_1_6?s=pc&ie=UTF8&qid=1438812724&sr=1-6&keywords=usb+3.0+hub
Is this a good brand, would you trust it? Any alternatives? I cant seem to find one that has a cable for data and a DC cable.
https://linustechtips.com/topic/424092-usb-30-hub-under-30/
its got good reviews and amazons return policy is gr8
https://linustechtips.com/topic/424092-usb-30-hub-under-30/#findComment-5693582
https://linustechtips.com/topic/424092-usb-30-hub-under-30/#findComment-5693588
if I am correct, each USB plug uses 1 amp, so if it says 5v/2.1 amp then that will only power two at full speed correct
Description says
"Supplies up to the 1.5A per port and 2.4 amps from the two charging ports "
https://linustechtips.com/topic/424092-usb-30-hub-under-30/#findComment-5693639
Description says
https://linustechtips.com/topic/424092-usb-30-hub-under-30/#findComment-5693659
https://linustechtips.com/topic/424092-usb-30-hub-under-30/#findComment-5693679
