If you're sure about the version number, then sorry, man. You're gonna need a BIOS upgrade. The G1620 works from BIOS version 0804 on.
The newest BIOS (ver. 1402) can be downloaded here: http://dlcdnet.asus.com/pub/ASUS/mb/LGA1155/P8H61-I_R2.0/P8H61-I-R2-ASUS-1402.zip
What threw me off a bit is that the version you mentioned has a lower number than the first release according to this: http://www.asus.com/Motherboards/P8H61I_R20/HelpDesk_Download/ Is it an engineering sample or something?
https://linustechtips.com/topic/423547-i-need-help/#findComment-5687523
