Hello everyone!
I just bought my first laptop yesterday and I found something kind of odd. Do not get me wrong, I love the laptop but the touchpad is awful..at least that's what I think. It makes a really bad rattling noise. I recorded a video and uploaded it for reference...here it is:
I have no idea if this is normal. It happens if I tap on it and I do not know if this is supposed to happen. Take into consideration that I just tap, I do not click. If I click the noise is a normal noise for a click. The touchpad feels kinda cheap and like it isn't secured properly. Like it is hollow. I am afraid not to have problems with it in the future as I will use this laptop quite a lot during college.
Should I return it or ask for a replacement? I need your asnwers.
Best regards,
Mihai Ilie
https://linustechtips.com/topic/423253-asus-touchpad-problemplease-help/
model number ?
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
The model number is:
Asus F550JX-DM020D
I think this is made especially for Romania tho.
does everything function correctly ?
1
Kind of...is just that..it sounds really broke.
you could try RMA it or take it back see what they say
1
