AIO Cooler Question
Go to solution Solved by tomas710,
Hi!
I've finally found an all in one cooler I like, but I'm having trouble finding out if I can put it where I'd like in my case. I have the Fractal Design Define R5, and I want to have the 280mm radiator near the front (I'd remove the top hard drive cage and put the radiator in its place). However, I'm a little confused about the length of the tubes. Will they be able to fit from the cpu block to the front of the case?
Thanks in advance for your help!
according to amazon the tubing is 16 inches, which is quiet long
https://pcpartpicker.com/b/rkzMnQ
A build with the R5 and a front mounted X60, not the exact same cooler but pretty much the same, it fits with room to spare
Hi!
Intel i9 9900k @ 4.00GHz // NZXT Kraken Z53 // MSI Z390-A PRO // Corsair Vengeance 64GB DDR4 // EVGA RTX 3080 Ti // EVGA SuperNOVA 750W P2 // Crucial MX500 500GB x5 // Seagate FireCuda 1TB Solid State Hybrid Drive x2 // Seagate BarraCuda 4TB HDD x2 // NZXT S340 Elite Tempered Glass Mid Tower //
https://linustechtips.com/topic/423210-aio-cooler-question/
Hi!
I had to take that gamble when i bought my corsair H105, there was plenty of length for me to work with, and i think the NZXT units are similar
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/423210-aio-cooler-question/#findComment-5682861
Hi!
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
https://linustechtips.com/topic/423210-aio-cooler-question/#findComment-5682918
