help with HTML :)
Solved by Hackzzila,
If you have two divs that you want to style differently you have to do it with classes, otherwise the divs will have the same styling. If you use classes you can target a seprate class instead of an element.
EDIT: You can use classes for every element
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4 -
4
play_circle_filled
Latest From ShortCircuit:
