If I have 4 2tb drives in raid 5 I would have 6tb or storage and one backup. If one drive fails how would the failed drive write to the 4th drive if it failed in the first place? I am confused as to how this works and need some help understanding it.
 Just because you don't care, doesn't mean other others don't. Don't be a self-centered asshole. -Thank You a PSA from the people who do not say random shit on the internet.
https://linustechtips.com/topic/421841-how-does-raid-5-work/
I know what it does. I am saying if a drive FAILS how does the raid get the data off it? If the raid loses a drove how does the extra drive replace the "dead" one?
https://linustechtips.com/topic/421841-how-does-raid-5-work/#findComment-5665507
Clearly you didn't watch, lol.
Nothing is taken off of the dead drive. It's dead. Rather, another copy of all of that data will be stored across the other 3 drives, and it just copies it over.
"Epic Voice, Quality Content"
https://linustechtips.com/topic/421841-how-does-raid-5-work/#findComment-5665530
This is the best explanation of Raid5 I've seen. Everything else implies the final drive is used as parity and somehow expects you to believe it all magically goes back together if one fails.
I didn't even watch it. I figured that posting a quick video is easier than me explaining it.
https://linustechtips.com/topic/421841-how-does-raid-5-work/#findComment-5665531
As the link in Matthew's post describes, for RAID5 often a simple XOR operation is
used to distribute parity information across the drives, then whenever one drive
fails you can work out what should be on that drive by doing some maths on what the
drives you still have are holding.
See also here: https://en.wikipedia.org/wiki/Parity_bit
and here: http://serverfault.com/questions/332634/how-to-calculate-raid-parity-bit
For RAID6, in case anyone cares, the maths is a tad more complex, although the
principle remains the same: Do some maths on the data to calcualte parity, then
put that somewhere else in the array, and in case of any drive failing, reconstruct
what was on that drive by doing the reverse maths on the parity information you
have on the drives which are still working.
https://en.wikipedia.org/wiki/Standard_RAID_levels#Parity_computation
Also some more: http://raid-recovery-guide.com/raid5-parity.aspx
Edited by alpenwasser
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
https://linustechtips.com/topic/421841-how-does-raid-5-work/#findComment-5665611
Ah. SOrry I thought it was another here is the raid levels and what they mean vid. I have watched like 10 with no explanation.
https://linustechtips.com/topic/421841-how-does-raid-5-work/#findComment-5665616
Yup, I use Two RAID 6 arrays with 6 drives total.
https://linustechtips.com/topic/421841-how-does-raid-5-work/#findComment-5665621
Thanks guys. So I have az97 ar which supports raid 5 but is it better to get a raid card?
https://linustechtips.com/topic/421841-how-does-raid-5-work/#findComment-5665626
