Depending on you how much data you have the process can be either super quick, or super slow. I would wait several hours and see.
If you forced the installation (which I think you did), then it could be stuck in the upgrade process with a driver, but the driver has a bug where it is stuck, and Windows 10 setup just waits indefinitely. If that is the case, you can revert back to your old Windows, and make sure all your hardware and peripherals drivers are fully updated. Be sure to uninstall all security software you may have installed as well, as they are known to cause issues, including anti-virus/anti-malware. If the problem still persists, then wait until your manufactures releases new drivers.
https://linustechtips.com/topic/421468-win-10-problems/#findComment-5661648
