my build (repost with better pictures)
BenD
Ok, this is the best i can do with picture quality,  if it still isn't good enough, buy me a god damn camera :P
so, i consider my build finished now. thought about getting a modular psu , but since i have no window in it i backed out from that.
also i think water cooling is cool, but considering the lack of room for rads and res. Not on this rig.
over a few years i might go all the way.
anyway enjoy the show :)
post-21153-0-05685900-1375457172_thumb.j
as you guys can see, i was very creative here :D i kept my ssds on the hdd mount and just screw that to my driver cage. Actually went really well
also don't have any ssd mounts on this case, so it's this or taping the things somewhere, but this way they have some cooling, and it's easy (kinda) for the cables to hook up.
post-21153-0-57684200-1375457178_thumb.j
also ,, drive cages can be usefull, look at the cable management, tell me that isn't genius :D
post-21153-0-29877900-1375457183_thumb.j
post-21153-0-93951300-1375457189_thumb.j
just look at the no room, if don't open this thing carefully, i rip my fan connector out and have to take my gpu out to reconnect it
only downside on corsair fans, if you use them on side panels, the cable is just to short (that's why i have that ugly 3 different colour cable going on)
post-21153-0-74045400-1375457195_thumb.j
post-21153-0-38039800-1375457200_thumb.j
post-21153-0-75823500-1375457204_thumb.j
post-21153-0-23834100-1375457207_thumb.j
post-21153-0-61579100-1375457211_thumb.j
post-21153-0-73457800-1375457214_thumb.j
post-21153-0-06490100-1375457341_thumb.j
so, got some simple monitors (when budget comes going to look at some things i saw other people use.
my keyboard is the logitech g110 (not bad, like the buttons, the buttuon sizes)
mouse is the logitech g600 , this thing sits just fantastic in your hand, way to much buttons, but a general cool look.
my sennheiser pc 363d (wich i'm using without the usb soundcard, because that just won't work with me, and no one can help out on that part apperantly)
i hooked up logitech Z5500 to my pc, because when i'm alone, i want to make some noise
also under my desk (can't take picture of that, to dark) i have a tv box hooked up to one of my screens and also to my speakers.  way better then any tv i ever had :P
(spared myself the cost of an tv  that way to) :D do have a tv with another box,  so i can still record programs and all from my desk and watch the recordings. Perfect solution if you ran out of room.
little tip for small room owners ;)
anyway , hope you kinda appreciate my work.
i try to be nice to all the other posts (except one time, wich give me the warning points, but that little ass ran away from the forum, and the moderator said i was right, but braking the law is braking the law :P , but it was worth it!!!! )
so be nice, any pointers i'm willing to take
I7 3930K @4.4 GHz  /  Asus rampage 4 formula  / 4x 8gb kingston hyperx blue low profile / gtx 980  / 2x ssd 500gb samsung 840 / 500gb 840evo ssd   /  500 GB WD blue /  windows 7 ultimate
my build: http://linustechtips.com/main/topic/133477-750d-finished/
Nice build, but the cable management.
not as easy as i thought, anyway it is better then last time there just no way to make it look better with these kind of cables
and that loos cable is just the only way. And i have no windows, so really this is good enough, and there is no clean way to extend fan cables, i found nothing in different stores here, this is wat found
It took me about 6 times to get the cable management perfect on mine.
i'm kinda without ideas, these cables just ruin in, in the back panel it's like cable madness, i just put stuff together there , came to the conclusion: damn it, now it won't close
so made smaller bundles.
if i had a windowed case then i would just get another psu with other type of cables and modular to ,
but air flow wise this is really good and at you gotta admit, my ssd solution is funny but good :p
but if you got any idea how to improve it without me getting a new psu, shoot! :p
but air flow wise this is really good and at you gotta admit, my ssd solution is funny but good :P
but if you got any idea how to improve it without me getting a new psu, shoot! :P
Mine is pretty bad in the back, but having a semi modular psu and zipties helped a lot. If I had a pic of it I would post it. I do like the SSD solution. Also I use to have that keyboard, but I upgraded to G510.
funny story, i went to my usual store for a keyboard, end this was the best one they had.
a few days later i was in another store (i think i was getting my 2nd monitor) and they had the g510 and it wasn't that much more expensive, so that was a fuck this shit moment :p
  • 6 months later...
What he said.  haha.  But as long as you're happy with it.
Any plans to push your OC more?
