Water Cooling pump Help
Solved by Oshino Shinobu,
This one should work. https://shop.ekwb.com/ek-xtop-ddc-plexi-original-csq
EDIT: Yep, if you look at the manual, it's the same model, so it will work. https://shop.ekwb.com/EK-IM/EK-IM-3831109842607.pdf
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases2 -
2
thrasher_565 ·
Posted in Hot Deals0 -
5
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning18 -
1
play_circle_filled
Latest From ShortCircuit:
