"The identity of the website is not identified "
"your connection with facebook.com is not encrypted"
how do i fix this im able to open all websites but not facebook and few other sites
Check your time on your PC. Are you sure you're on https://www.facebook.com
https://linustechtips.com/topic/420769-network-error-pls-help/#findComment-5652828
If your time is right and you are accessing https just give it some time and try again later. They may just be having an issue with their certificates at the time. If you try again later and you still receive this error it may be worth checking your proxy settings and ensuring no-one is trying to intercept traffic.
https://linustechtips.com/topic/420769-network-error-pls-help/#findComment-5657380
