Well well well...
I got screwed by google this time.
I just updated to android 4.3 with my galaxy nexus (rooted), and it got stuck in a bootloop.
I've tried wiping cache partition but no resaults.
While it was installing the update i got multiple messages from CWM recovery that the zip file signature was incorrect and untrusted, even though this was an OTA update.
I can probably fix this problem by wiping the cache partition, doing a factory reset and manually flashing the 4.3 image. But I don't want to loose all my data.
Any wizards out here who perhaps knows how to break a bootloop with the nexus without having to factory reset?
Much appreciated.
CPU:
Intel Core i5 2500k - Motherboard: Asus maximus iv gene-z - RAM: 2x Corsair Vengeance Blue 4GB DDR3-1600 CL9 - GPU: ASUS GTX 770 DirectCU II
Case: Coolermaster Centurion 5 II - Storage: Crucial M4 128GB, Seagate barracuda 3TB PSU: XFX 650W XXX Edition Modular PSU - Keyboard: Ducky Shine 2 Pro
Mouse: Razer Deathadder 2013 - Sound: Razer Characias
https://linustechtips.com/topic/42072-galaxy-nexus-bootloop-after-43-ota/
Maybe a possibility to sideload the update while in recovery?
CPU:
i thought installing cwm breaks ota updates? atleast it does on my xperia t......i would say just try and flash the rom from cwm if you can.......can you still enter cwm?
-Anubikai
| i5-4670k at stock until I do a custom WC loop | H80i | Asus Matrix Platinum 7970 at stock until I do a custom WC loop  | MSI Z87 GD65 | 1TB CAVIAR BLACK | 250gb Blue Scorpio | HX750 80 PLUS GOLD modular | 16GB INTEL EXTREME EDITION PATRIOT 1866MHZ | Coolermaster Storm Enforcer with two Red 20cm fans intake and exhaust |
-Anubikai
I have done an OTA update with CWM installed, instead it worked the other way around. The update worked fine but it broke my root and CWM :x
I have now reverted back to an old OASP backup i had laying around.
I'm now back to version 4.2.2 and will remain that way untill they fix the update.
I don't know whether it's a problem on my end or google's end.
Maybe in the future i'll backup my data and do a manual update.
CPU:
you can already install cwm and root the 4.3 rom for the galaxy nexus...just install the update and completely remove your root and cwm...then re root and install cwm...
or this
http://www.androidrootz.com/2013/07/stock-43-rom-for-galaxy-nexus-rooted.html
-Anubikai
or this
-Anubikai
With both suggestions i'd have to flash stock, which i don't want initially.
The ideal situation would be to flash just the update via CWM or something. So i don't have to flash stock but it just updates like normal.
I could obviously backup everything, flash stock, update and reroot etc but that would take so much work again, since i did that just recently.
I'll see if i can find a better solution than flashing stock. If not, i'll have to.
CPU:
