Hi Guys my name is Ethan and i need some help I have Hardline PETG Tube and I need to Put In A drain Port But I dont know if their are certain fittings that I need that are different from soft tubing I know I need a 4 connector a t valve and plugs but I am unsure which ones are compatible. If anyone could link me to some i would greatly appreciate it.
My build is mainly green monsoon hardline fittings so if you could color match two that would be a big pluse
https://linustechtips.com/topic/420428-petg-draining-port-help/
A T fitting and a valve is basically it you would need some extra hardline fittings to implement this or a dual ended male adapter.
https://linustechtips.com/topic/420428-petg-draining-port-help/#findComment-5649116
