I want to just design like the shell of a basic website (for practice) and i kind of want to have it in 3 sections, so i want there to be a section at the top with the title in it, then a section for the main body and then everywhere that isn't occupied with them i want an image, like in the image I've masterfully created in paint below, i was wondering how to do that :) i know how to put margins and put an image in the background etc but i don't know how to have a centralized body/header with a background image that is separate to these two. :)
i also want to be able to put images into these parts, so not just inserting a blank white space in the middle of the page :)
thanks in advance! :D
https://linustechtips.com/topic/419749-htmlcss-help/
Use dem divs, what program are you using?
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/419749-htmlcss-help/#findComment-5641138
I'm using notepad++ atm :) can you give an example of how to do this with a div? thanks :)
Gimme a sec..
<html>
  <head>
    <title>Example Page</title>
  </head>
  <body style="background-color:gray">
    <div id="header" style="background-color:white;width:800px;margin-left:auto;margin-right:auto;margin-top:25;margin-bottom:10;height:auto">
      <p>Test Text, though this would really be an image or something</p>
    </div>
    <div id="body" style="background-color:white;margin-left:auto;margin-right:auto;width:800px;min-height:300px;margin-top:0;margin-bottom:25">
      <p>More text! This time its in the body!</p>
    </div>
  </body>
</html>
The header div will get taller/shorter depending on how much stuff is in it, and the body will do the same, but will stay at least 300px tall.
Then in your CSS file you'll want to add padding for the text elements and such so they're not right on the edge. I wouldn't recommend adding the padding to the div itself as that causes it to grow slightly and works kinda funky.
https://linustechtips.com/topic/419749-htmlcss-help/#findComment-5641150
Haven't done that in notepad before sadly.
https://linustechtips.com/topic/419749-htmlcss-help/#findComment-5641156
Gimme a sec..
<html>
  <head>
  </head>
    </div>
    </div>
  </body>
</html>
yay that's what i was after! thank you!  :D is there anyway to manually tell it how big to be? because i want the body do go right to the bottom of the page :)
https://linustechtips.com/topic/419749-htmlcss-help/#findComment-5641242
Yeah, just add ";height:X amount of pixels, or X%" after the margin-bottom:25 style tag for the body.
I think setting it to 100% height would do it.
https://linustechtips.com/topic/419749-htmlcss-help/#findComment-5641254
okay, thanks a lot man appreciate it :)
Yw :P
https://linustechtips.com/topic/419749-htmlcss-help/#findComment-5641273
Here is a quick solution that works and uses HTML5.
The HTML code:
<!doctype html><html lang="en"><head>  <meta charset="utf-8">  <title>Example Page</title>  <meta name="description" content="Example">  <meta name="author" content="Me">  <link rel="stylesheet" href="link_to_your_Stylesheet"></head><body>    <header><!-- Your header Content Here --></header>  <main><!-- Your main content here --></main>  <footer><!-- Your Footer Content here --></footer></body></html>
The CSS code:
body{  background-color: blue;  margin:0;  padding:10px;}header,main,footer{  position: relative;  display:block;    /* Width & height */  width:100%;  max-width: 500px;  height: auto;  min-height: 50px;  /*Center*/  margin:auto;  margin-bottom:20px;    /*Padding*/  box-sizing: border-box;  padding: 10px;  /*Color*/  background-color: white;}
Business Management Student @ University St. Gallen (Switzerland)
HomeServer: i7 4930k - GTX 1070ti - ASUS Rampage IV Gene - 32Gb Ram
Laptop: MacBook Pro Retina 15" 2018
Operating Systems (Virtualised using VMware): Windows Pro 10, Cent OS 7
Occupation: Software Engineer
https://linustechtips.com/topic/419749-htmlcss-help/#findComment-5641844
