So I live in NZ and am only using this site (super reliable and covers alot of bases)
My build is this:
http://www.pbtech.co.nz/index.php?z=p&p=CHAAER8025&name=Aerocool-MT-Mid-Tower-Gaming-Case-Strike-X-Advance
http://www.pbtech.co.nz/index.php?z=p&p=CPUIT4790K&name=Intel-Haswell-Unlocked--Core-i7-4790K-4.0GHz-8MB-L
http://www.pbtech.co.nz/index.php?z=p&p=FANPHA0143&name=Phanteks-TC14PE-CPU-Cooler-Premium-Black-Edition-w
http://www.pbtech.co.nz/index.php?z=p&p=HDDCRU5500&name=Crucial-MX200-M.2-500GB-SSD-2280SS-SSD--555MBs-rea
http://www.pbtech.co.nz/index.php?z=p&p=HDDSE8040&name=Seagate-NAS-HDD-ST4000VN000-4TB-64MB-Cache-SATA-6.
http://www.pbtech.co.nz/index.php?z=p&p=MBDGBM2818&name=Gigabyte-G1.Sniper-B6-Gaming-Series-for-Intel-Sock
http://www.pbtech.co.nz/index.php?z=p&p=MEMGSK0519&name=G.SKILL-TridentX-16GB-(2x8GB)DDR3-2400MHz-(PC3-192 (x2)
http://www.pbtech.co.nz/index.php?z=p&p=OSYMSO8683&name=Microsoft-Windows-8.1-64bit-OEM-Eng-Intl-1PK-DSP-O
http://www.pbtech.co.nz/index.php?z=p&p=PSUCLM5850&name=COOLER-MASTER-V-series-850-GOLD-850W-80-Plus-Gold-
http://www.pbtech.co.nz/index.php?z=p&p=VGAGBV00992&name=Gigabyte-GTX980Ti-6GB-G1-Gaming-Version-PCI-E-3.0-
Any problems?
Only issue I can see is you dont need the unlocked CPU (K model) if you arent overclocking, if you want to overclock you will need a better motherboard, as the B85 series wont let you do this. You would probably want a Z87 or Z97 mobo.
Also people wont usually like to help as much on this forum if you dont use www.pcpartpicker.com so you should check that out.
My Rigs:
Gaming/CAD/Rendering Rig
Case:
 Corsair Air 240 , CPU: i7-4790K, Mobo: ASUS Gryphon Z97 mATX,  GPU: Gigabyte G1 Gaming GTX 970, RAM: G.Skill Sniper 16GB, SSD: SAMSUNG 1TB 840 EVO, Cooling: Corsair H80i PCPP: https://au.pcpartpicker.com/b/f2TH99SFF HTPC
Case:
Silverstone ML06B, CPU: Pentium G3258, Mobo: Gigabyte GA-H97N-WiFi, RAM: G.Skill 4GB, SSD: Kingston SSDNow 120GB PCPP: https://au.pcpartpicker.com/b/JmZ8TW
https://linustechtips.com/topic/419725-is-my-build-compatible/#findComment-5640827
