http://pcpartpicker.com/p/wDxMHx
That is my build so far and I am looking to a R9 280x but I am unsure of which one I want to get. I am looking to stay near $600 and I would like to play Battlefield 4 and CS GO with this build. All help finding the best price/performace GPU will be appreciated!
https://linustechtips.com/topic/419369-need-help-deciding/
get a seasonic SSR-550M or a 650M because corsair cx psu's are generally snake oil.
https://linustechtips.com/topic/419369-need-help-deciding/#findComment-5636587
http://pcpartpicker.com/p/978BRB
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/419369-need-help-deciding/#findComment-5636609
The best R9 280Xs are Sapphire's dual-X, vapor-X and toxic. However you might also want to look into the R9 380 4GB, it performs basically the same as the 280X but has 4GB of VRAM. You can find Sapphire's Nitro 380 4GB for about the same price as the 280X.
http://pcpartpicker.com/parts/video-card/#c=148,182,310&r=4096,3072&sort=a8&page=1
Intel i5-4690K @ 3.8GHz || Gigabyte Z97X-SLI || 8GB G.Skill Ripjaws X 1600MHz || Asus GTX 760 2GB @ 1150 / 6400 || 128GB A-Data SX900 + 1TB Toshiba 7200RPM || Corsair RM650 || Fractal 3500W
https://linustechtips.com/topic/419369-need-help-deciding/#findComment-5636622
Oh cool.
https://linustechtips.com/topic/419369-need-help-deciding/#findComment-5636643
Is that a good card? I am not to familier with that card either btw this is my first buid.
yes this card is a newer version of 280x it is actually a better overclocker and has 4gb of vram not 3 this card will last at 1080p for at least 1-2 years
https://linustechtips.com/topic/419369-need-help-deciding/#findComment-5636654
Oh ok, but im not sure this build will be able to overclock due to the cooling.
yes you will be able to run your gpu just fine really also this build like i said will run whatever game you want it to at 1080p
https://linustechtips.com/topic/419369-need-help-deciding/#findComment-5636690
Is the Gigabyte a trustable GPU or not because theres no reviews.
yes gigabyte makes great gpus and are one of the best on par with msi and evga
https://linustechtips.com/topic/419369-need-help-deciding/#findComment-5636740
So you think this specific one will be ok?
yes definitely you should have no issues and this gpu should be great
gigabyte also makes great motherboards too so rest assured that the gpu should preform very well
https://linustechtips.com/topic/419369-need-help-deciding/#findComment-5636785
