Difference between GTX 680/660
Solved by technovore,
there's three major brands of graphics card producers: AMD, Intel and Nvidia
Intel does mainly IGPU's, the higher the number the better.
AMD uses a 4-digit-based system to designate a card, the first number indicates what series it's from, the higher the number in a serie, the more memory and processing power the card has.
Nvidia uses a simular 3-digit-based system, the first number indicates what series it's from, the higher the number in a serie, the more memory and processing power the card has.
Sometimes two different graphics cards can have the same memory but different processing power, thus creating the difference.
