I am planning on building my first gaming pc at the end of this month my budget is 600-650 euro.
I already have a 1080p monitor, keyboard, mouse and an os.
I live in Ireland and I priced a build on nxic.com and here is what i got:
Ram: G.skill ripjaws 8gb 1600mhz
Mobo :Msi 970a-g46 atx
Cpu: Amd fx-8320
Gpu: Gigabyte geforce gtx 760 oc
Psu: CORSAIR CX SERIES CX600M
Hdd: wd blue 500gb
case: Zalman z11 case is being bought in ireland
On nxic after checking international shipping total came out to 641
If there is anything you would add in or change please let me know and if you could find a similar build or better that can be bought from Europe please let me know thanks.
https://linustechtips.com/topic/41855-building-first-gaming-pc/
personally i would consider getting more storage, 500 gb fills up mighty quickly and hdd storage is so cheap that it would not cost much more.
For example http://www.amazon.co.uk/dp/B006L3Z95G/?tag=pcp0f-21
I am just trying to fix to a budget but I will probably purchase the bigger hdd thanks.
https://linustechtips.com/topic/41855-building-first-gaming-pc/#findComment-543745
Seems pretty good, however you might want to look out for international shipping fees, you might have to pay VAT and customs and other stuff that makes it alot more expensive. Personally i would upgrade to a 1TB instead of 500 GB, since its not much more then the 500 version. A ssd would be awesome as well, but you can always add it later.
Cpu: Intel core i5 4570 gpu: gtx 770 case: cm storm enforcer psu: xfx pro 550w motherboard: asus b85m-g ssd: samsung 120gb hdd: wd caviar blue 1tb ram: kingston hyperx blu 8gb 1600mhz mouse: razer deathadder monitor: some decent samsung 19" keyboard: CM Storm TK Blue
https://linustechtips.com/topic/41855-building-first-gaming-pc/#findComment-543800
