Phanteks Enthoo Pro. Spending more than $100 on a case is a waste of money.
http://www.amazon.com/Phanteks-Enthoo-Chassis-Window-PH-ES614P_BK/dp/B00K6S1B3Q
not in the case of the thermaltake x9 but i would suggest the enthoo pro as well
also "CASE" get it
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/418329-help-find-a-case/#findComment-5624368
And I forgot I'm Canadian so we have to spend around 23% more for the exact same item. So could u guys plz with a .ca at the end instead of a .com on the websites. Thx
https://ca.pcpartpicker.com/part/phanteks-case-phes614pbk
https://linustechtips.com/topic/418329-help-find-a-case/#findComment-5624413
