Hi there, I recently (15 minutes ago) installed new fans in my NZXT H440 case. These were; 2 Noctua F-A14 FLX at the front of the case and 1 nf-p14s-1200 at the back replacing the stock NZXT fans that come in the case.
However, I have noticed they are a bit noisy, I think it is due to them being connected to the fan hub, meaning they're running at full speed. So my question is this, are there any fan controllers you would recommend allowing me to control the fan speed?
I have looked at the NZXT Grid+ and it seems decent enough. Any suggestions?
Thanks
Midori:
Specs: Intel i5 4690K | Asus Strix GTX 1070 |  2x4gb Corsair Vengeance DDR3 @1600MHz| Samsung 850 Pro 250GB | WD Blue 1TB | EVGA Supernova G2 750W | NZXT H440 Black/Green
Cooling:|2 Stock NZXT Case fans | 2 Noctua F-A14 FLXNoctua NF-P14S-1200 |
Peripherals: Corsair LUX RGB K70 Silent| Corsair RGB Sabre | Audio Technica M40X
OS: Windows 10 Pro 64bit
https://linustechtips.com/topic/418052-fan-controller-for-nzxt-h440/
I use a 6 way PWM Fan splitter to control my fans off the motherboard, nice simple way to do it! If you want them to be different speeds though you'd have to group them with multiple splitters!
I've noticed that my Motherboard (Asus z97-A) supports fan control in the BIOS, But the only fan listed is my CPU Fan. I have all my fans connected via the fan hub at the back of the case and they are all 3 pin connections..
I think the NZXT Grid+ would be a good option, but it only allows all the fans to be controlled simultaneously. Is there any problems with that?
Midori:
