Okay I find I'm VERY VERY OCD about my cables looking neat and perfect. I find I'm cutting and re running multiple times cause I forget X cable needs to run using Y loop that is already used with Z cable. How do you start your cable runs? System cables, front io, main power? Wish do you run first?
https://linustechtips.com/topic/417213-cable-running-help/
Front IO, CPU and 24 Pin, Then The rest of power cables, Then the other cables like sata and stuff
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
https://linustechtips.com/topic/417213-cable-running-help/#findComment-5610683
