700W PSU Advice
I'm in Australia and i'll probably be purchasing it from here http://umart.com.au/newindex2.phtml?bid=2. It sucks that Australian prices are notoriously higher than US :/
I'd like to keep it <$180. But I don't want to spend more than I have to, like SLI and crossfire capability won't be required
Yeah...Prices in Australia are indeed higher than the US, especially with certain brands like Corsair, Seasonic, Enermax, etc... Apparently, Cooler Master is one of them as well sadly...
http://www.vtechindustries.com.au/cooler-master-700w-vanguard-full-modular-power-supply-rs-700-afba
Anyways, if you are able to purchase it here, the Super Flower Golden Green 600w is an excellent unit that is also quiet. The Capstone I had mentioned is based off of this unit, so as the NZXT Hale90, PC Power and Cooling MKIII 750~850w, etc. http://www.itestate.com.au/pages/product/pdt_product_detail.faces?BeanName=productDetailAction&pcode=16156
Here's the Seasonic G SSR-550RM recommendation I had made for $115 AUD: http://www.mwave.com.au/product/sku-aa49474-seasonic_g_series_550w_power_supply_atx_eps_80plus
If you want to get the 650w variant of the Seasonic G, here: http://www.i-tech.com.au/products/137307_Seasonic_G_series_650W_PSU_80Plus.aspx
The HX650v2 is the same internally as the Seasonic G, btw. I typically don't recommend it (HX650v2) due to lack of four native PCIe connectors when the retail model does have four, but since you aren't SLIing, it doesn't really matter.
