Mayhams coolant?
Go to solution Solved by ,,,,,,,,,,,,,,,,,,,,,,,,,,,
You just need to add distilled water & yes performancepcs is good. I've used them.
If I buy Mayhams pastel white , do I need to add anything to it. and is Performance pc.com a good place to buy it and other watercooling parts?
For their premixed stuff it's ready to go out of the bottle if it's the concentrate you'll need some distilled water from the pharmacy or grocery store to mix it to a total of 1L.
PerformancePC is a good place to get watercooling stuff in the US.
https://linustechtips.com/topic/415348-mayhams-coolant/#findComment-5587522
