What are your Specs?
What do you plan on Water Cooling?
YOU DON'T NEED A GIANT ASS CASE!
Cpu: Intel core i7 5930k
Motherboard :Asus rampage v
Memory :Corsair platinum 32gb ddr4 3200mhz
Psu: Corsair ax1200i
Storage :Samsung 850pro 256 gb
2xWestern digital caviar black 3 tb
Graphics :2 way sli gtx titan x
https://linustechtips.com/topic/415316-help/#findComment-5587951
what case do you have right now
What is the GPU manufacturer?
also why the super overkill power Supply
Because he had a hard drive.
https://linustechtips.com/topic/415316-help/#findComment-5588007
I need a new tower for a custom watercooling system but I can't choose. I am between the corsair 900d and the enthoo primo! what's your opinion guys ??
The 900D is just massive, i don't see why not to go with an Enthoo Primo, it supports 2x480mm, 2x240mm and a 140mm rad natively, that's WAAAAY more that your would ever need
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/415316-help/#findComment-5588026
