Hi I have a gigabyte hd 7950 http://www.gigabyte.com/products/product-page.aspx?pid=4121#ov
and I have a benq 24''monitor and it works fine when I have it connected trough the dvi port on my hd 7950 but when I switch to the hdmi port I says hdmi no signal
I thought it was the display's problem but when I used a dvi to hdmi adptor to see to connect the monitor through its dvi port it didnt work. It only worked on the graphics card dvi port.
The reason I want to connect it through hdmi is because I have a second monitor I connect through dvi
https://linustechtips.com/topic/415137-hd-7950-hdmi-problem/
