Fan suggestions
Go to solution Solved by Gix7Fifty,
Forgot to mention: On a budget of about $50...
The case comes with 2 intakes and one outtake
In that case keep chasis fans on low and the CM Hyper 212 Evo will get you a decent overclock and keep thermals at bay.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139044&cm_re=air_240-_-11-139-044-_-Product
So I'm planning on buying this, but I want suggestions on fans for the fan slots, along side of what fan to put on my I5-4690K.
This computer will be used for heavy gaming and recording, both on the same rig.
GPU currently runs about 42C when recording and playing. 37C gaming.
CPU currently runs about 62C when recording and playing. 47C gaming.
I just want better over-all cooling for both.
GIGABYTE Z97MX-G516GB DDR3 | I5 4690k @ 4.4ghz | 1TB SSHD, 500GB HDD, 128GB SSD | GTX 1070 8GB | Corsair Graphite 230 | EVGA 650W | Hyper 212 EVO
Cinebench R15: 636(all cores), 127FPS
https://linustechtips.com/topic/414848-fan-suggestions/
Noctua NH D14/15 for the cpu and 2 Noctua NF-S12A intakes 1 Noctua NF-S12a exhaust.
https://linustechtips.com/topic/414848-fan-suggestions/#findComment-5581679
Those are good temps i don't think fans will decrease temps by much if any.
I just want them so I can OC my cpu a little. Its running at stock 3.5GHZ
https://linustechtips.com/topic/414848-fan-suggestions/#findComment-5581710
Forgive me El Guapo. I know that I, Jefe, do not have your superior intellect and education...
https://linustechtips.com/topic/414848-fan-suggestions/#findComment-5581711
Do you know if CPU fans come with thermal paste pre-coated and/or thermal paste packets?
https://linustechtips.com/topic/414848-fan-suggestions/#findComment-5581741
pre applied. Temps are fine up to 90c.i run mine at 70c 24/7 boinc youll be fine.
Sorry... long day at work. Wording isn't my strong suit right now x.x
https://linustechtips.com/topic/414848-fan-suggestions/#findComment-5581769
