Weird HDD Overheating Problem.
Go to solution Solved by alpenwasser,
If I've read correctly, your HDD is around 40 C now, that's nothing to worry about.
Your drive is spec'd for up to 60 deg C ambient temperature and 69 deg C drive case
temperature (page 17): http://www.seagate.com/staticfiles/support/docs/manual/desktop/Barracuda%207200.12/100672652b.pdf
Although personally I try to keep my HDDs below 50 C.
EDIT:
Oh, just got your second post. That's a bit hotter, but still tolerable according
to the specs. There isn't really that much you can do besides improving ventilation
for the drive or relocating it, which I guess is not an option.
Hello guys, I finally bought an aftermarket cooler for my AMD Phenom II X4 955 Processor, the Arctic Cooling Freezer A11 and it solved my noisy stock fan issue... But now another problem emerged... HDD overheating ! This came out of freaking nowhere but I suspect that the Aftermarket CPU Cooler is the culprit cause it's LARGE in a mini MOBO and micro atx case... But how an Aftermarket cooler, however large may be contribute to only HDD overheating... I dunno...someone help me please... Here a picture with the stock cooler and with the aftermarket one.
post-244871-0-56116900-1437772790_thumb.
Case : Zalman R1 Motherboard : Asus Prime Plus B350  CPU : AMD Ryzen 5 1600 @3.2GHZ  RAM : Corsair Vengeance 2x8GB @2400MHZ (OC) SSD : Samsung 850 Evo 250GB + Patriot P200 500GB  HDD : Seagate Barracuda 2TB  GPU : AMD RX 5700XT 8GB  PSU : Corsair CX 550W
https://linustechtips.com/topic/414716-weird-hdd-overheating-problem/
A little edit, that was the first day I installed my cooler. 3 days ago that is ... Right now, if I play games like Heroes of The Storm for hours , it climbs to like 49-51 celsius... It's ridiculous.
EDIT:
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
Right now , at this exact moment, my HDD is on 45C . But I'm idling... I have like 5 tabs of chorme and a music player... Thanks so much for the info and the readme of the exact HDD I appreciate it. I will read it right now. Thanks a bunch!
No problem. 45 C is not cool, but it shouldn't cause issues. My drives usually
run between 32 C and 47 C, depending on model and ambient temp.
Well I have 3 choices. I can either lift the thing from it's "hdd cage" and screw it a little higher so that it won't come in contact with the HDD cage and then secure it better with cable ties so it won't fall. Second choice is buy an HDD cooler , like some fans of some sort or otherwise relocate my HDD. Thats the  harder part , cause the case is tiny and I don't think I have room for my 3.5 HDD...thing's huge... What should I do from these 3 options? Thanks a lot!
