My next step into finalizing my built is getting some extra fans.
My setup needs two AirFlow fans and two Static Preassure fans. With white LEDs.
Since I'm using a Corsair Vengance C70 case, plan was to remove one HDD bay (not planning to use it) and stick an AF fan on the front slot.
Under that where the HDDs are at I wanted to have two SP fans, in front and back of the bay.
And then the final AF fan to replace the exhaust.
First I was thinking to use the Corsair LED fans, but after doing some digging, many users reported them as being quite... awful.
So what else can I have as alternative? The Specter fans from Bitfenix?
These two couples need to have the same LED setup for asthetics purpouses, since AF and SP go in the front.
If someone has any suggestion, thank you in advance.
Last thing, I might consider modding these LEDs so I can switch them off. I work at an electronics factory so I should have all the needed tools. Question is: how difficult could it be? Since at the end I'm pretty much hooking every LED in my case to a fan controller for flexible dimming.
https://linustechtips.com/topic/413909-led-fans-help/
-SNIP-
Most LED fans are kinda less than amazing I definitely recommend if you want lighting to have regular fans and LED strips it will give more even lighting while not having issues with dimming when running LED fans on less than full speed.
https://linustechtips.com/topic/413909-led-fans-help/#findComment-5572317
Bitfenix spectre pros are very well rounded fans, and they come in white
http://www.newegg.com/Product/Product.aspx?Item=N82E16835345041&cm_re=spectre_pro-_-35-345-041-_-Product
AeroCool Sharks, heard good things about them
http://www.newegg.com/Product/Product.aspx?Item=9SIA7B42W01733
Air penetrators are awesome for focused airflow and have good static pressure
http://www.newegg.com/Product/Product.aspx?Item=9SIA4TZ35A4103&cm_re=ap121-_-35-220-044-_-Product
For airflow, i recomend this ID-COOLING fans
http://www.newegg.com/Product/Product.aspx?Item=9SIA59T1Y58308
I would put AP121s as intake and on the hard drives and the ID-cooling fan or an aerocool shark in the rear
And i have to mention the TB vegas since IMO are the best looking LED fans out there and very good overall, i mean, you could simply use 4 of them
http://www.newegg.com/Product/Product.aspx?Item=N82E16835214052&cm_re=enermax_tb-_-35-214-052-_-Product
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/413909-led-fans-help/#findComment-5572718
Are the Riing fans also good for Airflow?
Have no idea, they look good. I haven't seen any reviews from them.
Processor : i7-6700k (stock speed)
Cooler : Hyper 212X
Motherboard: MSI Krait Gaming Z170
RAM : 4x4gb LPX Memory
Boot Device : Samsung 860 EVO
GPU : ZOTAC 1070 Extreme
PSU :Antec HCG-620M
https://linustechtips.com/topic/413909-led-fans-help/#findComment-5573653
Sorry, kind of a noob question, how would I use the LED strips to be powerd on when my computer is and where is the best place to buy some.
https://linustechtips.com/topic/413909-led-fans-help/#findComment-5578367
It's not too difficult most are powered via 12V molex or sata and will turn on when your PC turns on, if you want brightness control some are wired to 3 pin fan headers so your can use DC voltage control via the motherboard or fan controller to vary the brightness.
Some good LED strips are the Darkside strips, or Bitfenix Alchemy strips but are a bit pricey for what they are.
There are also some Industry Affiliates on the forums that sell pre-made LED strips, such as Addon Customs or ModGuru.
https://linustechtips.com/topic/413909-led-fans-help/#findComment-5578476
Thanks
https://linustechtips.com/topic/413909-led-fans-help/#findComment-5578505
