I have 2 140mm fans on top of my case (air 540) and I assume that sticking a rad on top with fans under the rad would affect how much air  can be exhausted therefor raising the temps of all the other components
CPU: I7 4790k  CPU Cooler: NH-D15 GPUMSI 970 4gb   Motherboard: z97 Gaming 5 PSU: Corsair hx850   Ram: Corsair Vengeance 8 gb  SSD: Samsung 850 Evo  Case: Air 540
https://linustechtips.com/topic/413900-would-using-a-rad-affect-overall-cooling/
A little bit less air would get exhausted, but it doesn't really matter that much to actual temps.
GPU: Gigabyte GTX 970 G1 Gaming CPU: i5-4570 RAM: 2x4gb Crucial Ballistix Sport 1600Mhz Motherboard: ASRock Z87 Extreme3 PSU: EVGA GS 650 CPU cooler: Be quiet! Shadow Rock 2 Case: Define R5 Storage: Crucial MX100 512GB
the overall heat will be less though. the marginal overall restriction may affect parts by like .5*C, but by taking 80tdp of a cpu and dumping it straight out of the case, vs just dumping it in the case, can greatly improve the overall temps of other parts.
