So heres a picture how it looks like.
Monitor: BENQ XL2411T like a year in use
ASRock Z68 Pro 3
GTX 770
I just recently noticed it when i woke up and moved my mouse to wake up screen. It will flicker and the gray or blue lines might turn vertical if i click buttons but it wont get back to normal. The problem seems to only go away after waiting like 2 minutes but it is starting to take longer too sometimes. So this happens every time screen comes back to life from either turning on pc or from sleep. I can use pc on my tv when the problem is on if i have "copy screens" selected. The picture on the pc screen will switch a little depending on what kind of website i am.
Didnt update anything when this problem appeared, only the critical flashupdate on every browser i use.
Had both cpu and gpu overclocked but problem still appears when i turned them down.
post-141314-0-79748700-1437552938_thumb.
https://linustechtips.com/topic/412784-screen-problem/
