Can't fold? Help!
Go to solution Solved by Razarza,
http://imgur.com/YxAYzrn
I've tried updating, it does the same thing... :(
But have you tried uninstalling it and then installing it again? I know it sounds silly since it is already a fresh install but I've had times where I needed to reinstall F@H twice before it would work properly.
Hey guys! I did a lot of F@H a while back with my 4790k and Radeon 7770. I decided to stop until I got a GPU that could score better PPD than that 7770. I recently acquired a Radeon R9 280 and would love to start again, but the client simply won't let me. (Tried a few weeks ago with one of the 7770's, same issue)
Basically, off of a fresh install of F@H, when the web control is opened it will connect, display nothing but 'loading' then it says:
The Folding@home software on your computer has most likely stopped.
Please first restart it, then reload this page.
Restarting makes no difference. Open the F@H Advanced Client, and this message is displayed:
On client "local" 127.0.0.1:36330: Option 'gpu-index' has no default and is not set.
Click 'OK', and you're left with a screen that displays nothing of use, just says 'Updating' on the top bar but doesn't appear to be doing anything.
Help?
Project Tomahawk:
CPU: Intel Core i7 4790k
Motherboard: Asus Maximus VII Hero
CPU Cooler: Corsair H100i
Memory: 16GB Kingston HyperX Fury 1866 Mhz
GPU: Asus Strix RX 480
PSU: Corsair RM1000
Storage: 2x Western Digital 2TB Enterprise + 240GB Crucial M500 SSD
Case: Corsair Air 540
Additional: Cablemod C-Series black/red kit, SP120, AF140 and AF140 w/ red LED's all around
Project Frankenstein:
CPU: AMD FX 6100
Motherboard: MSI 970 SLI Krait Edition
CPU Cooler: Cooler Master Hyper 212 EVO
Memory: 8GB G.Skill Ripjaws X 1866 Mhz
GPU: MSI R9 280 3G Twin Frozr
PSU: Seasonic M12II EVO 620W
Storage: Western Digital 1TB Enterprise + 240GB Partiot Torch SSD
Case: Fractal Design Define S
Sheila (Server):
Dell R210:
CPU: Intel Xeon x3450
Memory: 12GB Crucial ECC 1600 Mhz
Storage: Seagate 3TB Constellation
Marvin (Server)
Dell R210ii
CPU: Intel Xeon E3 1230v2
Memory: 12GB Crucial ECC 1600Mhz
https://linustechtips.com/topic/412498-cant-fold-help/
I think I found the same issue you're having here: https://foldingforum.org/viewtopic.php?f=67&t=20446#p203513
Open advanced control, go to Configure, click on the Slots tab, Select the GPU slot, hit edit and then set the gpu-index to -1
Hopefully that helps :)
Specs: CPU: AMD FX 6300 Motherboard: Gigabyte 970A DS3P RAM: HyperX Fury 16GB 1866MHz GPU: MSI R9 270 OC edition Case: Sharkoon VS3-S SSD: Samsung 840 EVO 120GB HDD: 1TB Caviar Blue PSU: Corsair CX500W
*If I say something that seems offensive, please don't take it seriously, it was most likely meant as a joke/sarcastically*
https://linustechtips.com/topic/412498-cant-fold-help/#findComment-5551350
The only tab I have in Configure is Connection. I'm using FAHControl 7.4.4.
Project Tomahawk:
PSU: Corsair RM1000
CPU: AMD FX 6100
Sheila (Server):
Dell R210:
Marvin (Server)
Dell R210ii
https://linustechtips.com/topic/412498-cant-fold-help/#findComment-5551698
That isn't right, can you share a screenshot please.
4790k @ 4.5Ghz 1.180v NZXT Kraken X31 | MSI Z97 Krait | Kingston Hyper X Fury 32GB 1866Mhz, 2 DIMMs white and 2 black | GTX 980 Ti - G1 Gaming | GTX 680 - Reference | SilverStone ST75F-P | Phanteks Enthoo Pro
https://linustechtips.com/topic/412498-cant-fold-help/#findComment-5556190
http://imgur.com/vRp40Y4
Project Tomahawk:
PSU: Corsair RM1000
CPU: AMD FX 6100
Sheila (Server):
Dell R210:
Marvin (Server)
Dell R210ii
https://linustechtips.com/topic/412498-cant-fold-help/#findComment-5556216
Ah I see, try opening the web interface, if that doesn't get it to finish updating then give it a reinstall.
https://linustechtips.com/topic/412498-cant-fold-help/#findComment-5556269
Project Tomahawk:
PSU: Corsair RM1000
CPU: AMD FX 6100
Sheila (Server):
Dell R210:
Marvin (Server)
Dell R210ii
https://linustechtips.com/topic/412498-cant-fold-help/#findComment-5556300
https://linustechtips.com/topic/412498-cant-fold-help/#findComment-5556331
Yup, that did the trick. Thanks man :P
Project Tomahawk:
PSU: Corsair RM1000
CPU: AMD FX 6100
Sheila (Server):
Dell R210:
Marvin (Server)
Dell R210ii
https://linustechtips.com/topic/412498-cant-fold-help/#findComment-5556401
The F@H client is a fickle bitch isn't it, glad to hear that it is now working for you. Also remember to put the team number, passkey and all that shit in, last thing you want to forget to do.
https://linustechtips.com/topic/412498-cant-fold-help/#findComment-5556412
yup, managed to find my old one :D Back to contributing for the LTT Team!
Project Tomahawk:
PSU: Corsair RM1000
CPU: AMD FX 6100
Sheila (Server):
Dell R210:
Marvin (Server)
Dell R210ii
https://linustechtips.com/topic/412498-cant-fold-help/#findComment-5556644
Also, quick question... the 280 has a WU that is apparently going to take 2.6 days and  award me with 8000 points? should I be concerned? My 7770's did better than that... also, My i7 doesn't seem like it wants to start the WU assigned to it.... problems problems problems :D
Project Tomahawk:
PSU: Corsair RM1000
CPU: AMD FX 6100
Sheila (Server):
Dell R210:
Marvin (Server)
Dell R210ii
https://linustechtips.com/topic/412498-cant-fold-help/#findComment-5556696
Don't worry about that, give it a few hours to stabilise and you'll be golden.
https://linustechtips.com/topic/412498-cant-fold-help/#findComment-5556725
