Raspberry pi issue
So I get a raspberry pi b+ today in bloody hot wether (although I don't think it was out for a while). I install openelec on a sd card and it doesn't work. So I installed the disk image on to the sd card and that doesn't work. I am was so mad . I decided to try raspbien (I am not sure if I spelled that right) and it doesn't work. Any help please!
https://linustechtips.com/topic/412476-raspberry-pi-issue/
Is it connected to the wall plug? :P Hey, you never know
[spoiler=My PC]
CPU: Intel Core i7 6700K | COOLER: Corsair H105 | MOBO: ASUS Z170i Gaming Pro AC | RAM: Corsair LPX DDR4 16GB 2400MHz | GPU: EVGA GTX 980 Classified | CASE: BitFenix Prodigy | SSD: Samsung 950 Pro 512GB | PSU: XFX XTR 650W [spoiler= Le Other Stuff] Monitor: BenQ XL2411Z | Keyboard: Ozone Strike Pro | Mouse: A4 Tech X7 F4 | MousePad: Ozone
PlayStation 2 | PSP 2000 | Game Boy Color | Nintendo DS Lite | Nintendo 3DS | Wii
Sony Xperia J (Why u so bad D:) | iPod 4th gen | iPhone 4 | Yarvik Xenta 13c (3muchchrome5her)
Pentium B980 | 500GB WD Blue | Intel HD Graphixxx | 4Gegabeytes of REHAM
Current OS: MSX 10.0 ( ͡° ͜ʖ ͡°)Ilikethelennyfaceyouknow( ͡° ͜ʖ ͡°) Windows Password Reset Guide
https://linustechtips.com/topic/412476-raspberry-pi-issue/#findComment-5550995
Try a different SD card if you can. I had a similar issue using a Lexar MicroSD card in my Raspberry Pi 2 Model B (the 1gb version). I ended up returning it and getting an Adata one. The Pi recognized it as it should and installed Raspbian without any issues.
I know there is also a list somewhere online of compatible MicroSD cards for the Raspberry Pi. That might help you.
EDIT: Also, make sure the card is formatted as FAT32.
Main Rig: CPU i7-4790k / MOBO Asus Z97-Pro (Wifi-AC) / RAM 16GB HyperX Fury 1866 MHz / CPU COOLER Dark Rock 3 / GPU Asus GTX 1070 Strix  / CASE Evolv ATX Tempered Glass / SSD Crucial MX200 250GB / HDD  WD Black 1TB + WD Blue 3TB / PSU EVGA 750G2 / DISPLAYS 2x Dell U2414h / KEYBOARD Corsair K70 RGB Cherry MX Brown / MOUSE Logitech G602
Laptop: Dell XPS 15 / i7-6700HQ, 16GB RAM, 512GB SSD, GTX 960m, 1080P Display
Cheap Windows/Office Keys
https://linustechtips.com/topic/412476-raspberry-pi-issue/#findComment-5551054
the sd is fat 32. I did originally try an adata one before this one and it didn't work. But it did ship from Bulgaria.
https://linustechtips.com/topic/412476-raspberry-pi-issue/#findComment-5551081
Well it could be that the Pi is defective. I thought the same thing for mine until I read that it might be the SD card.
https://linustechtips.com/topic/412476-raspberry-pi-issue/#findComment-5551167
so what shuld I do?
I would make sure you followed everything on this page: https://www.raspberrypi.org/help/noobs-setup/
If nothing gives, then try to get a replacement.
DISCLAIMER: I am far from an expert on Raspberry Pi's. I'd maybe do some more research before the RMA.
https://linustechtips.com/topic/412476-raspberry-pi-issue/#findComment-5551251
ok have a good day!
https://linustechtips.com/topic/412476-raspberry-pi-issue/#findComment-5552364
Follow up question. So I got a new sd card and I installed noobs and It worked. But I accidentally started installing the real raspbein. I didn't want to do that I wanted openelec so I unplugged it. I put openelec on the sd card nothing happened. So I put noobs back on. It sorta worked. It said I didn't have enough space. So I formatted the sad card (over write) and put noobs back on. Then when I plugged it in nothing happened. Can I get some more help?
https://linustechtips.com/topic/412476-raspberry-pi-issue/#findComment-5560884
