cpu power
Go to solution Solved by catbedead,
Thanks very much. Most appreciated.
Hi, I am building a new pc and I am using the I5 4690k for my cpu and Msi z97 PC mate for mb. The thing doesnt start even tho the pci-e cable connector on the gpu lights up, so there propably is power in the system. The thing is that the pc doesnt boot, and I was wondering if it could be becouse of the 8 pin cpu power conector that I only have 4 pins for since I am useing an old 500 w psu from my old rig. Coud this be the problem??
https://linustechtips.com/topic/412210-cpu-power/
If the motherboard has an 8 pin connector, and you only plug in a 4 pin, it doesn't work.
Pick up a new power supply and try again. :P
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/412210-cpu-power/#findComment-5547561
Thanks for the quick response. I'll head out now and get a new PSU.
I am looking at a corsair cx600m. Will that do the job?
http://www.corsair.com/en/cx-series-cx600m-modular-atx-power-supply-600-watt-80-plus-bronze-certified-modular-psu
https://linustechtips.com/topic/412210-cpu-power/#findComment-5547581
You said you have a 4690k, what GPU do you have in the system?
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/412210-cpu-power/#findComment-5547661
asus gtx 760.
Then you should be fine with the 600m.
Enjoy the build once its up and running!
And welcome to the forums!!
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/412210-cpu-power/#findComment-5547726
Don't overclock with that PSU it should only be used for basic builds
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/412210-cpu-power/#findComment-5548755
