Silent-ish computer build help?
Go to solution Solved by xTrekStorex,
get Noctua fans as mentioned above (NF and AF ones) and connect them to your mobo instead of the PSU (if you havent already) so you can control them. if the EVGA doesnt have a decent fancontroller (I dont know that board but I have experienced every onboard/software controller except from ASUS to be junk) then get some hardwarecontroller like the Bitfenix Recon, NZXT Sentry or AeroCool Touch Series. If you want something to program and leave be, a mCubed T-Balancer is also really nice.
remember to get appropriate fans with high static pressure for that h110i radiator.
you could also remove all the dust filters to increase airflow but I wouldnt recommend it since then you can clean your rig every 2-3 days.. ;)
Hey guys! First post here so please bear with me
So I've finally built my first computer and realized that it is pretty loud due to the fans installed. (It being on the table beside me doesn't help either).
I am currently using the stock fans that came with the case and my H110I GT
Here is my part list:
Case: corsair air 540
Mother board: EVGA Z97 FTW
Cpu: Intel i7 4790
Cup cooler: corsair H110I GT
Ram: corsair vengeance pro 2x4 gb 1866
Video card: still pending
Fans: stock
I know my case isn't the best sound proofing case and neither is my pump. But I was wondering if anybody has any recommendations on quiet fans that may help reduce some noise coming from my computer (preferly with LED)
https://linustechtips.com/topic/411993-silent-ish-computer-build-help/
Have you tried lowering your fan speeds?
Lower the fan speeds, or get some Noctua fans for ultimate quietness-itude
Main PC: 4690k, LMG Edition G1 Gaming GTX 980, 16GB Hyper X Fury, Asus Z97-A, EVGA G2 850W, Crucial MX100 128GB, WD Red 1TB 2.5", Dark Rock 3
Laptop: Asus UX305 Monitor: Asus PB278Q Keyboard: Filco Majestouch 2 TKL Mouse: Corsair M65
Bitfenix Phenom M White | ASUS RoG Maximus VIII Gene | Intel i7 6700K @4.6GHz | HyperX Savage 2800MHz CL14 DDR4 16GB | EVGA GTX1080 SC | Intel 750 Series PCIe SSD 400GB | EVGA SuperNova G2 550W | Windows 10 Professional x64 | Logitech G900, Corsair K70 RGB MXbrown O-ringed, BeyerDynamic DT880 (600 Ω) on Fiio E10K & Samson Meteor | Dell U2715H 27", Samsung SyncMaster P2450H 24", Samsung SyncMaster 931BF 19" | DIY Ambilight
Cpu: Intel i7 4790
Fans: stock
Is that a locked CPU? and for most people noctua fans are too expensive. First you have to change the fans on the rad, corsair fans are just way too loud, AP141s from silverstone are good, if you want LEDs, Bitfenix Spectre Pro or thermaltake rings, for the rest of the case, so many options, you would use the bitfenix or the thermaltake rings if you want lots of leds or silent wings 2 for quietness, noctua is always an option, just rather expensive.
For the cooler Noctua NF-P14s Redux are a good option too, and are cheaper than other noctua fans
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
Cpu: Intel i7 4790
Fans: stock
Is it the i7 4790k?
I would recommend cougar vortex or rosewill hyperboreas for the case fans and silent wings 2 for the radiator fans
so i ended up getting 2 noctua NF A14  and a NZXT sentry 3 and man oh man what the difference was!
although the factory corsair blue led fans were pretty sick with my build the fan noise was driving me nuts!
talking about fan controllers:
are there any lcd displayed fan controllers that will be able to support landscape and portrait mode? the sentry works like a charm but my ocd self is wishing that the informations displayed are oriented straight instead of sideways.
