full water cooling loop help
GPU: EK 970 GTX WF3 (out of stock here, but you can find it somewhere else. Must be the WF3 version) https://www.overclockers.co.uk/showproduct.php?prodid=WC-737-EK
Pump: EK Laing D5 Vario w/ top https://www.overclockers.co.uk/showproduct.php?prodid=WC-409-EK&groupid=962&catid=2141
Fittings: Any 13/10mm compressions. https://www.overclockers.co.uk/productlist.php?groupid=962&catid=1529&sortby=nameAsc&subid=2582&mfrid=
Tubing: Primochill 13/10mm clear (or whatever colour) https://www.overclockers.co.uk/showproduct.php?prodid=WC-097-PM&groupid=962&catid=1530
Coolant:Use a clear coolant and dyes if you want it coloured. That would be my advice. They all perform the same really https://www.overclockers.co.uk/productlist.php?groupid=962&catid=1531&sortby=manual_sort&subid=&mfrid=596
