I have a 2 monitor set up using an Acer G257HU (1440p) as the main monitor and a HP x2301 (1080p) as a secondary monitor.  Currently I have an EVGA SC 2GB GTX 770.  I get between 30-60fps on mid to high settings at 1440p.  I am wondering if I should upgrade to a R9 390 or just stay with what I have.  I have about a $340 budget and if I should upgrade should I get an MSI 390, Asus DCIII 390 or Sapphire Nitro 390.
Thanks for the help in advance.
https://linustechtips.com/topic/411547-keep-or-upgrade/
It would be like going to a 970 and a bit over actually so yes, you will see a performance increase and with 2 monitors, one of which 144p, you will be able to make us of the 8 gigs of VRAM.
As for the cooler, either Asus DCIII or Sapphire, both are great in my honest opinion. Work will begin shortly on a compilation list for the different coolers' performance so you might also wait for that if you are unsure :)
https://linustechtips.com/topic/411547-keep-or-upgrade/#findComment-5539642
If what you are running with now is okay for a little bit longer, I'd wait until you can afford a 980
Adobe Photoshop Graphic Artist and PC Building Enthusiast
Corsair 750D | I7 4770 | Aorus Waterblocked 1080ti | z97A Gaming 7 MSI | EVGA supernova 750 G2 Gold | 900P 280Gb 256GB 850PRO 128 GB 850 EVO| 32GB Corsair Vengeance (4x8GB) | Logitech g502 mouse | Corsair K70 Cherry-MX Brown | Full Custom Water Cooling Loop |
https://linustechtips.com/topic/411547-keep-or-upgrade/#findComment-5539651
Make sure you follow your posts to get replies. And I'm not sure if we can help you with that. It's just personal preference, if you have the money to spend, and you would like the nicer card, then go for it. But if you're okay with lowish framerates, then save your money for now.
"LTT's official.."STOP. I promise you aren't LTT's official bagel eater or whatever. Trust me.
https://linustechtips.com/topic/411547-keep-or-upgrade/#findComment-5539663
If he's gonna save up for a 980, he might as well save up $100 more for a 980 ti.
https://linustechtips.com/topic/411547-keep-or-upgrade/#findComment-5539677
Yeah, thats what I thought for the most part, was going to wait a bit anyway as I don't think Asus DCIII 390 is out yet.  Was also going to wait for windows 10s official launch to see how well drivers boost performance.
https://linustechtips.com/topic/411547-keep-or-upgrade/#findComment-5539679
Well, we are currently working on the list of cooler performance here, feel free to add input abut the 770 and your cooler :)
http://linustechtips.com/main/topic/411543-attention-techies-unite-and-put-the-silicone-lottery-to-the-test/
https://linustechtips.com/topic/411547-keep-or-upgrade/#findComment-5539687
So get the R9 390 :)
Main PC: CPU Xeon E3-1231 V3 - MB Asrock B85M Pro3 - RAM 16GB Kingston - GPU GTX 1070 Gainward Phoenix - PSU Corsair AX760i - Monitor  LG 22EA63 - Keyboard Corsair Strafe - Mouse Logitech G402 - Storage 2x3TB WD Green - 240GB OCZ SSD
https://linustechtips.com/topic/411547-keep-or-upgrade/#findComment-5539703
Ok, thanks will definitely be sure to take this into account when I finally decide to upgrade.
https://linustechtips.com/topic/411547-keep-or-upgrade/#findComment-5539712
If you're going to upgrade now, go for the GTX 970 instead of the R9 390. From what I've read (could be wrong) the 970 blows the R9 390 out of the water; the 390 just has more vRAM.
I run a 970 with a 1440p main monitor and 1080p secondary, and I get well above 60fps at 1440p on most games at max (or near-max) settings.
W/ Nvidia Shadowplay, I can keep and record full 60fps in Battlefield 4 on Ultra, in TF2 I get between 150 and 300 fps playing, and can hold 90-150 while recording 60fps video.
"Epic Voice, Quality Content"
https://linustechtips.com/topic/411547-keep-or-upgrade/#findComment-5539733
Actually, you are very much wrong. If you don't trust me, watch this
https://linustechtips.com/topic/411547-keep-or-upgrade/#findComment-5539763
I think the 8gbs of vram would help future proof my rig so I won't need to upgrade for awhile.
https://linustechtips.com/topic/411547-keep-or-upgrade/#findComment-5539789
