comp is built and needs checking
Solved by Guest,
it just means that speedstep is disabled or you have the power limit set to use your CPU max power 100% of the time which is fine
Don't worry.
Edit:
Also the clocks very by a MHz, Btw your processors speed range is 3.5-3.9 excluding OC's , 4790k is 4.0-4.4
derekchan ·
Posted in New Builds and Planning4 -
1
5
kerriya ·
Posted in Cases and Mods8 -
octester ·
Posted in Troubleshooting7 -
DavidPatrascu ·
Posted in General Discussion9
play_circle_filled
Latest From ShortCircuit:
