I wouldn't get the Kingston SSD. Crucial BX100
What do you do? Why do you need a 4790k? Is it just for gaming if so a 4690k is fine.
All this you should be able to get a GTX 980 or 390x
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/411135-will-my-build-work/#findComment-5534495
What is the difference between the two ssds?
Kingston SSDs aren't that fast. I mean coming from a HDD you'd notice a difference but if you had like a crucial bx100 or Samsung 850 Evo and went to a Kingston 300 you'd notice it's slower.
https://linustechtips.com/topic/411135-will-my-build-work/#findComment-5535396
