So i installed my new MSI R9 380 and tried sniper elite 3 with ultra settings with it and i was getting a comfortable 100 fps but i noticed that my GPU tempature was 95 degrees Celsius...then i realized the fans werent spinning at all so i put on user defined fan speeds on MSI afterburner. Anyone know why they didnt spin at the start? Are you supposed to manually enable them or is there some sort of error here?
CPU Intel Core i5 6600k @ 3.5GHz GPU MSI Radeon R9 380 4GB Motherboard Asus Z170 Pro Gaming RAM Kingston Fury 2x4GB DDR4 2666MHz PSU XFX 650W Storage Seagate 1TB, WD Blue 1TB, Kingston 128GB SSD OS Windows 10
https://linustechtips.com/topic/410833-fans-not-working-properly/
is there any switch on the card that says silent or fans off?
Try running a benchmark or intense hardcore gaming
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
No i didnt find a switch for fans on the card and i didnt touch anything on afterburner until i realized the fans werent spinning.
Also I noticed this
Core/Memory
  • Core Clock / Memory Clock
    1000 MHz / 5800 MHz  (OC Mode)
    980 MHz / 5700 MHz(Gaming Mode)
    970 MHz / 5700 MHz (Silent Mode)
You are probably in Silent Mode.
Get MSI Gaming App from their website or just make your own profiles in Afterburner...
Well i downloaded the MSI gaming app and ran the sniper elite 3 benchmark with different modes gaming mode and OC mode. On gaming mode the temps were around 70 degrees celsius wich is acceptable but on OC mode the fans didnt spin until the temps reached 96 degrees and even then they just span for 2 seconds and stopped again until it reached 96 degrees again...
